Need some advise for vehicle AC refrigerant.
So my brother has a 2014 Dodge charger and it has the newer refrigerant r1234yf and he the car was not blowing as cold as it used to, he lives in Florida. He picked up a self service can and somehow added about 1/3 of a can of r134. He said the the connection seemed a bit tight but that some did get in. I read the can and figured out that it was the wrong stuff. So I guess my question is what should he do? Will this ruin his system? can he just have the system vacuumed down and replaced with new r1234yf? Any assistance and or advise would be helpful. Thank you and Happy Holidays.
Mixing refrigerant is a big problem. If he takes it to a shop the machine will test it. When it finds it contaminated it will lock out the machine! Usually takes 3-4 weeks for robinair to come out and reset. Also costs $1000!
In the mean time the shop is losing revenue since the machine is locked out. He needs to take the truck to a shop that has a way of recovering the mixed refrigerant and disposing of it properly which your friend will be on the hook for.
I once tried refilling my F150 with one of those cans and the sealant in the can plugged up the A/C expansion valve, never again will I try any type of at home A/C fix. I'd take it in to an A/C specific shop and explain what happened.
You're never going to get it all out doing what some of you are thinking you would do.
You will if you pull a hard vacuum on it with a rental kit.
What are the risks of leaving as is? Will the system fail? If so any idea on how long he has ?
Thanks for all of the replies. I appreciate it.
It's not illegal if you put it on a barge out to international waters.
what you do is you discharge it into a balloon, then lash that balloon to an inflated helium balloon, & set both free.
Do this after dark.
OT: I thought R134 was introduced because R12 was bad for the ozone layer....why did they introduce this new expensive y1234?
