I am once again seeking advice from the elders, this time on a troy-bilt horse tiller. I have read countless topics on this and other forums about how troy-bilt originally recommended gl-1 90 or 140 weight gear oil in the tillers. Well since I live in the south and summer temps are typically in the 90's and 100's, plus factor in the leaking tine seals I need to replace, I have decided on the 140 weight gear oil. Only problem is, unless I want to order a 5 gallon bucket of the stuff, my only option is gl-4 gear oil. Is the gl-4 any risk to the gears in the tiller? I have read the gl-4 has a lot less additives than gl-5...but gl-1 is non existent in my area. I am not too familiar with gear oils, so not sure what is ok to use. I know most gl-5 bottles say "yellow metal safe", but again not very sure if that includes the older equipment. Also, would adding Lucas oil stabilizer to the gear oil be ok? In the summer heat, the tine seals behind to vent/seep the gear oil over time since a tiller being a tiller tends to sit up most of the year unused. I'd like to drain out the old gear oil but not until I know I have the correct replacement on hand. I would rather not use multi-viscosity due to it being mostly liquid like at room temperature, which would not help the seeping problem while sitting up most of the year. Thanks for the help fellas!!!!!
