running a engine which turns 8000rpm's on a highly modified lawnmower engine. it sees cylinder head temps in excess of 500 degreesF. the horsepower measures on a dyno is over double that of stock.
running 9:1 compression on a ported and polished tecumseh 7hp engine. the deck has been shaved to the point that the piston protrudes out of the cylinder, the cylinder head is flat, the only thing keeping it from hitting the head is the headgasket. the cylinder head has been shaved as well as hogged out for better flow. the intake and exhaust ports have been ported and polished and port matched to the intake manifold and carborator. running triple stage header and aftermarket camshaft and springs.
it has splash lubrication so id like somthing thin when cold, but really thick when hot. i live in south florida so i dont need a very thin oil when cold, maybe 5w or so.
does anyone make like say a 5w70?
because of the excess heat and splash lubrication, i also need somthing with a very high flash point, and also somthing that resists shear EXTREMLY well, basically very little viscosity improvers are wanted in this oil.
i know this would make for an expensive oil, but im willing to pay for it.
id like to stick to brand names. will consider anything otc, amsoil, redline and royal purple.
so, what do you guys suggest?
