Thanks guys, I ended up buying some Rotella T 15W-40 because I couldn't find the 10W-30. Napa is getting me a filter (P-70 interchange) for it, as well.
The car is really nice and I love driving it. Everyone gives me thumbs up, which is cool. I'll tell you a secret though: I am only 28 and have owned only fuel injected cars. But I work on my cars quite frequently (I am a EE in my day job). After moving into this house 2+ years ago, my neighbor eventually approached me and explained about her husband and the car. She asked if I had ever worked on an old car. I grinned because I knew it would be fun. And it has been. I love fuel injection but everything is so simple on this car. I changed the carb in like 20 minutes, first time ever, no manual. Gotta love that.
The car appears to be very well engineered for the time period, and according to research, was probably one of the best cars of the decade as far as overall design quality and durability. And I'm a GM guy
Anyway, I changed the carb because the threads leading into the bowl were actually totally stripped. Her husband had a totally functional carb sitting on the shelf so I put it on. Seems like maybe the secondary/power jet/valve may still be clogged based on drivability.
I had a problem with the water separator gasket breaking up and clogging the screen, stranding me multiple times until I figured out what it was. Probably the E10 gas.
Had a fuel pump problem that also stranded me. The pin that the diaphragm arm rides on actually fell out. I took everything apart, and found a spare fuel pump on the shelf. I put that on but it had a bad check valve. So I put the old fuel pump back together and put it back on - it's been fine since.
Then I had a charging problem requiring me to learn all about points-style voltage regulators. Got the points filed and adjusted and it seems to charge now.
Had a serious braking problem which turned out to be just low fluid. I filled up the master, and pumped the brakes like 100 times. Brakes work well now, with a high pedal, and I never had to bleed anything. This would be impossible with the ABS on my cars.
Set the idle, changed the oil filter oil, topped off the coolant, cleaned the spark plugs (they are in good shape and I was diagnosing a no-start condition).
So.....I figured time to change the oil, too
It's given me no problems the last few times I've taken it out.
One thing's for sure - I'm not going to let it sit and rot. It needs to be driven occasionally, based on the things it needed to go back in service after sitting for 5 years.
