Need help with 2 oils
Iowa
I've been looking for an oil capable of an extended drain and good to great cold weather flow. Naturally Mobil 1 Advanced Fuel Economy 0w30 is pretty high on the list, but since I have access to the Petro Canada line, I figured I'd try to stack it up against the Mobil 1 Advanced Fuel Economy...
Problem is that I'm a bit confused. Looking at MRV values, the M1 is way lower, but the viscosity index of the PC 0w30 is noticeably higher, making me think that it would be thinner at most all points?
Could someone help clarify this for me please?
Links:
Petro Canada 0w-30
What is the MRV for PC? I did not see it in the document you provided.
Based on the two viscosities though and Widman's calculator, the PC should be thinner than M1 in extreme cold.
The MRV is stated in the PC data sheet as "Borderline Pumping Viscosity" and references the same test method (D4684) as M1.
