How many have you stripped?I like my capri 6 point ratchet wrenches
If you ever work on a Mercedes you will find etorx. They're a little easier to strip than a hex bolt
3 or 4 but they were small and rusted down a sizeHow many have you stripped?
Yep plenty of them lolI like my capri 6 point ratchet wrenches
So Capri tools is referring to Etorx as “star”? That’s the same thing?I bought this set over 4 years ago and couldn't be more pleased with it for a take along set, everything in one place.
I does not include Torx Plus security or long ones but for most jobs it works well. The quality is not Hazet, Stahlwille or Snap on but it is remarkably good for a tool in this price class, you actually get more than you paid for. The fit of the bits and sockets is good and the finish is excellent, even the case is good and worth keeping. I have used them a lot and nothing has broken, for $55 you cant go wrong, I paid more than this for one Snap on wobble Etorx.
https://www.amazon.com/Capri-Tools-CP30031-Master-60-Piece/dp/B00ESN02G2
Yes it is.So Capri tools is referring to Etorx as “star”? That’s the same thing?
If you look at it it can only this deep. A impact or deep impact may offer a little more contact area.This is an example of bolt on the Cherokee I need to get off. The caliper bracket bolt has a tall head. A lot of these sets would only grab the top half this bolt. So do I need a kit with a deeper taper at the end? Or does it not matter?
I don't think it matters. A box end wrench might seat further down if you're concerned, but you may have to use a cheater.This is an example of bolt on the Cherokee I need to get off. The caliper bracket bolt has a tall head. A lot of these sets would only grab the top half this bolt. So do I need a kit with a deeper taper at the end? Or does it not matter? View attachment 214470
Looks like a E20, no?This is an example of bolt on the Cherokee I need to get off. The caliper bracket bolt has a tall head. A lot of these sets would only grab the top half this bolt. So do I need a kit with a deeper taper at the end? Or does it not matter? View attachment 214470
I'm eagerly awaiting the release of TorxMax that will soon after be made obsolete by the arrival of the far superior TorxUltra.I've always wondered if we really needed a torx plus, I mean is there a torx that didn't hold well?
Nah, quintuple-square is where it's at. Then to be superceded by quintuple-square^2I'm eagerly awaiting the release of TorxMax that will soon after be made obsolete by the arrival of the far superior TorxUltra.
What about a perfectly smooth cylindrical design? Impossible to strip! The next iteration could add a taper.Nah, quintuple-square is where it's at. Then to be superceded by quintuple-square^2
Comes in 10mm! It's NUCLEAR!!What about a perfectly smooth cylindrical design? Impossible to strip! The next iteration could add a taper.
Thanks. Watching an Amazon video review of a Tekton Etorx set, the reviewer showed how the Tekton set only went about halfway down the taller head Etorx like this pic and was wobbly, but his “Hazet” 900S-E20 fit perfect. Hazet is German and expensive but Amazon does sell individual sockets. Are you familiar with that brand?Yes it is.
That one of my main tool brands along with Stahlwille, I have all the Hazet Torx, E-torx, Innen hex and XVN. I use the Capri for convenience working away from my place. Hazet and Stahlwille easily rivals Snap on or any other with this type of tool.Thanks. Watching an Amazon video review of a Tekton Etorx set, the reviewer showed how the Tekton set only went about halfway down the taller head Etorx like this pic and was wobbly, but his “Hazet” 900S-E20 fit perfect. Hazet is German and expensive but Amazon does sell individual sockets. Are you familiar with that brand?
https://a.co/d/5l8td7a
I need to find a set of hazel or stahlwille.Its good to have a selection, for the larger ones Hazet impacts are great and a good value, they last and fit well.
