Originally Posted By: jdmstr22
Normally a purolator PL14459, WIX 51334, FRAM XG9688 is there any bigger filters that will cross with this im looking for somethig with better flow and more capacity.
I'll predicate my two pennies of advice on the fact that you're probably running at or less than OEM OCIs ... If you are into e-x-t-e-n-d-e-d OCIs, then my comments would not apply here.
I presume this is a "want", because I doubt you have a "need" for a larger filter ...
First of all, do you have any conclusive proof that the current spec'd filter is somehow failing to provide the required cleaning aspect to your engine? Do you have any current standard of reference whereas your current OEM filter design is insufficient in flow and capacity? If you were to upsize to a larger filter, do you have any baseline measurements that would be able to prove beyond a doubt that a flow/capacity increase would equate to "better" protection? Do you have used oil analysis and PCs, standardized with known sigma variance, to show how much change (if any) would be attriubted to the filter versus other inputs?
Please know that, as a generalization, OEM filter abilities are typically grossly over-spec'd. A "normal" filter will often flow about 2x more oil than the engine would ever hope to move about, and hold probably 2-3x more dirt than it would ever generate and ingest, in a NORMAL OCI.
Let's look at just three examples:
Wix 51348 and Wix 51516 and Wix 51515. Here's an example of small, medium, large with the same overall fitment attributes (gasket size and thread pitch). If they could fit physically, given any space considerations, they would be essentially interchangable. All three are flow rated at 7-9gpm, and all three are rated at beta 2/20=6/20. Essentially, they all perform the same, regardless of size. I would certainly agree that the larger the filter, the more holding capacity the media would have, presuming the media is of identical construction. But unless you plan to GREATLY extend your OCI, you're never going to usurp the holding capacity of even the smallest filter.
If you're just adamant about having a bigger filter, go over to the Donaldson site and use their attribute x-ref feature; you can select thread pitch and gasket size, and then browse from there.
But know this: while it may matter to your head, where you "feel" that bigger and more is "better", it likely won't matter one little iota to your engine. What you want and what your engine needs are two totally different things ...
