well... in terms of a transmission cooler, which would be more effective? coolant from engine/radiator or atmosphere air?
basically, i have a irreparable leak at the transmission cooler fitting and leaking ATF fluid. i will need a NEW radiator to solve this problem. NOTE: this is not coolant and ATF mixing. the ATF fluid is just leaking from the fittings not seating properly.
i want to bypass my OEM transmission cooler but i am afraid it will not sufficiently cool the fluid. since it will not be cooled by coolant and now by air. the vehicle is a 94 1.5L honda civic, daily driven. i rigged my radiator switch to ON always so there is constant airflow, regardless of what my engine temperature is.
will this suffice?: Automatic Transmission SuperCooler rated at 9,800 BTU 11"x5-3/4"x3/4"
the basically stated i should get a larger (1) since i am bypassing the radiator coolant, but i am not sure if that is necessary.
http://www.bmracing.com/core/media/media.nl?id=8881&c=723089&h=aebd1b9e432dfa7a216d
