Thanks. So my guessing was right with G 055 529. You can pass the "A2" btw,
that's just the size of the container ("A2" = 1 L bottle).
@Jimmy_Russells: The dry-clutch 7-speed DQ200 is happy with VW G 052 171,
which was also used in MQ350 manual transmissions (before it was replaced by
G 052 527 in late 2012 for the MQ350). At least that DQ200 used to be factory
filled with VW G 052 171 in the past.
Generally MTFs and DCTFs seem to be rather similar. Some DCTFs are permitted
to be used in MTs as well, e.g. Motul Multi DCTF (> VW G 052 527).
MOTUL HIGH TORQUE DCTF - VW G 052 182 & VW G 055 529
Motul Multi DCTF - VW G 055 512 & G 070 726
So there seems to be some choice. Castrol, Fuchs/Pentosin, Motul, Ravenol, perhaps
some more and of course OE VW/Audi, which should be either Castrol or Fuchs made.
