I am doing a brake upgrade and the banjo bolt I have is slightly too long for the crush washers and hose I am using. I already shaved down the bolt to where the threads start and didn't want to go further. After shaving I have .010" clearance from the bolt bottoming out in the caliper with the hose and two washers installed.
All of the copper washers I have are .060" thick max. I need at least a M10 x 2.0 washer. 2.5mm or 3mm would work even better for clearance. Anyone have a source for thicker washers? Auto parts around me have 1.0mm thick.
Can I stack the washers? Also, I was thinking of using aluminum if I couldn't find them in copper.
