Need a source for a fuel pressure gauge inline adapter.
wtd
southwest Mo.
I'm trying to test the fuel pressure and check for fuel pressure bleed down on this 99 Cavalier that we just bought. I have a Mac 1100MS master fuel pressure kit. The car has 3/8" fuel line and the adapter in the kit for 3/8 only has it on the metal side of the adapter. The plastic quick connect end is smaller and won't fit on the barb on the fuel rail where the line from the tank attaches. Nothing else in the kit will work.
This is what the adapter looks like that is in my kit. I cannot find any information anywhere that tells me if any of these type adapters are 3/8 on both ends.
https://www.amazon.com/OTC-OTC51852...0dd17af62e58e048653f961&qid=1754338967&sr=8-1
I built my own. My fuel pressure test kit has an inline adapter with hose barbs on each end and a 1/4 inch flare (standard GM fuel pressure test fitting) in the middle. I use fuel injection hose (not fuel line hose, injection hose is rated to higher pressure) and nylon fuel line repair fittings from the parts store to adapt to the factory unions.
This ⬆️ might be the only solution @wtd. I went and looked at an old manual from my NAPA FI system cleaner and it only has 5/16" and 3/8" hairpin connectors; it truly is odd that yours doesn't fit.
  • Like
Reactions: wtd
I may have to do that. My kit also has that inline adapter that you are talking about. I will see if my parts store has the fuel line repair fittings. Thanks.
My kit has both the 5/16 and 3/8 hairpin connectors but the one side of the 3/8 is not 3/8 but looks to be the smaller 5/16.
I called Mac today and talked to someone in their tech support and they could not give me an answer as to whether or not the black female part of the 3/8 connector is also supposed to be 3/8 or not. I told him that it doesn't make sense why their 3/8 adapter would not have the same size on each side of it. He is going to contact their product development team and see what they say.
This is pretty frustrating to say the least.
IME adapting this stuff is exactly as frustrating as the OP has found. I have a big import kit from Amazon, the Cornwell kit and the SUR&R adapter kit (FPT290) and even then it's hit or miss. Typically I wind up pulling out all three and mix 'n matching.
edit: I had to slightly machine a banjo bolt once for a CRV and I've ordered other specialty fittings for the Toyota 3.4 V6
  • Like
Reactions: wtd
It's pretty crazy that the kit I have wouldn't have what I need to hook up to a pretty common car. I'm going to go the route that Timmastertech has suggested and fab up something with some replacement ends.
I've looked at the Snap On Master kit in the past and again today but it's crazy money but it seems to have more of the inline quick connect adapters that a lot of the newer vehicles seem to have. If it wasn't so expensive, I might think about buying it just to have as another option.
