I have a 98 Subaru that is starting to seep from the cam seals during cooler weather.
I am not a big fan of additives,but I do know there has to be something out there that will work. I dont want to play the hit and miss game until I find it.
The cam seals in the head {I have 4 of them} located in the front as it is a double overhead cam boxer engine is going to get rather messy soon as at least 2 are starting to seep now...Further since my timing belt is just in front of the leaking area,there is a cause for concern..puddles are already hitting the ground.
It is an interference fit engine that will destroy itself in the event of a timing belt failure..so it is imperative that that the cam seals are softened back up.
I am using German Castrol engine oil 00 30. I stocked up about 4 years ago..I am now down to one quart.
So I have no problem switching to another motor oil which may soften my seals...I dont know anything about Max life or its effectiveness...I do know that I used to beat down conventional Valvoline oil rather quickly which would show in a reduction in oil pressure at less than a thousand miles.
I am fond of oils that have the ACEA A3 rating ,so would like to stick with that if possible..if not I want an oil that will that will not be beat down very fast..something that will go 10 thousand miles plus and stay in specs....And is known to have seal longevity in mind.
