need a mechanic, Hermitage TN
So. Cal
Just moved to Hermitage TN and did not take my tools with me. I have a 2021 CX-5 Turbo that needs to spark plugs. I have the plugs just trying to find someone to install. I called a local shop and they will not install custom purchased parts. I could do it myself but that would mean buying the needed tools and I'm not ready to go the route. Any suggestions on a local mechanic that might help?
Mark's Automotive Repair Center in Old Hickory gets good reviews. But they're probably like most places which won't install customer supplied parts..
cx-5 turbo should be inline 4 with the plugs on top.
E Z M O D E.
Not as straight forward with the turbo. plugs are covered up by other components that need to be removed. The non-turbo is easy peezy
As someone who owned quite a few subarus I'd still say EZ, but you are right there are a few bolt ons with the turbo.. its not hyundai elantra easy :)
Should still be a 30min job with a $99 craftsman set and a spark plug socket.
unlike subaru... No need to jack the engine up and remove engine mounts to access the plugs 😂
You could just call that shop back and have them order the plugs you want installed.
I think you'll have to go to work with locals. Maybe a local church if you're into that. Or local Jeep clubs. You likely need an indy one-man hack like myself.
I'm steadily becoming the unofficial mekanik of our church and I'll do customer supplied parts after a Come-To-Jesus talk about how I can't stand behind the parts in any way.
But yeah, you might be better off to return four plugs (or eat the cost) and just go the mainstream route.
