GON
$150 Site Donor 2025
The below picture might likely get me a involuntary vacation from BITOG.. but........ has to be posted....Reading threads like these makes me wish I had chosen a different path in life sometimes.
It’s pretty expensive to play navy as a grownup too …The below picture might likely get me an ts involuntary vacation from BITOG.. but........ has to be posted....
Well…The below picture might likely get me an ell…involuntary vacation from BITOG.. but........ has to be posted....
Star Trek was heavily influenced by the Navy. It was the Navy in space. The ship itself was named after the carrier.Reading threads like these makes me wish I had chosen a different path in life sometimes.
I can imagine being in that reactor room is the closest experience you can get to being on Star Trek.
"Jordy, we need to maintain warp 9.8 for a few hours"
"Aye sir!"
Because the future of mankind is being stuck inside a tin can.Star Trek was heavily influenced by the Navy. It was the Navy in space. The ship itself was named after the carrier.
The ship was commanded from the bridge, had a Captain, helmsman, navigator, engineer, and used torpedoes. The ranks were all USN.
Sorry, Army. Sorry, USAF. The future of human civilization, as envisioned in that series, was based on the US Navy.
Well, I don’t think that was the point of Star Trek, was it?Because the future of mankind is being stuck inside a tin can.
I was joking, but with flight times to Mars using the physics we currently understand being measured in months at best, I think the tin can reference is pretty accurate. Not to mention the artificial habitats that we would need to live in there.Well, I don’t think that was the point of Star Trek, was it?
They managed to visit a lot of strange new worlds. They sought out new life, and new civilizations. They boldly went where no one had gone before.
Kirk himself seemed to have a rather active social life…
Q: Is the shaft hollow...like my TrueTemper framing hammer? I ask that 'seriously' as I was told surfaces compound the strength and keep a shaft light.Now, imagine the torque it takes to twist a shaft several feet in diameter 360°.
I always thought they were "screws" and ideally left the water still.The propellers themselves are a bit over 20 feet in diameter, they are moving a lot of seawater.
They call them screws, but they are propellers. I believe the terms are interchangeable.I always thought they were "screws" and ideally left the water still.
Yeah and arent the props 5-6 tons plus each. Simply amazing.By the way, the gear reduction is planetary gears. The housing for them is a bit over two stories tall.
So, steam turbine spins, turns gears, gear output is a shaft several feet in diameter. It’s roughly 300 feet from the gearbox to the propeller itself.
When power plant is developing maximum torque, that shaft has a full 360° twist in it.
Put another way, if you drew a big pencil line along the top of the shaft when it was at rest, and then looked at under full torque, that line would spiral around the shaft, one full revolution.
Ever seen a socket extension twist under torque?
Check out the "rope drive" in the '61 Tempest - the engine was in the front, and the transmission ( as you said) was in the back. They were connected by a flexible driveshaft, which spun at the same RPM.as the engine.Q: Is the shaft hollow...like my TrueTemper framing hammer? I ask that 'seriously' as I was told surfaces compound the strength and keep a shaft light.
I only just heard the driveshaft in the old Pontiac Tempest was a 3/4" shaft (engine to rear mounted transmission).
Screw is the colloquial term, propeller/propellor is the technical term. One of the earliest ship's propellors had a shape similar to a corkscrew. A propellor head is however not a synonym for a screw head.I always thought they were "screws" and ideally left the water still.
Each of the seven Emma Maersk E-Class container ships has one 31-foor diameter, 131-ton propellor. Those are the largest ship props ever made. They turn at up to a little over 100 RPM.Yeah and arent the props 5-6 tons plus each. Simply amazing.
It’s easy to play Army. All you need is a hole in the ground.The below picture might likely get me a involuntary vacation from BITOG.. but........ has to be posted....
It has happened.I can't imagine the vibration if one of those props threw a blade.
It has happened.
I posted this several months ago, and, yes, there was huge vibration when it let go.
The Nimitz-class props are around 25’ tall, weigh 66,000 lbs each of solid bronze, and at full tilt are making nearly 3 revolutions per second.It has happened.
