- Joined
- Nov 2, 2021
- Messages
- 1,116
Just spent an hour web surfing all I get is over 50% nascar teams choose mobil 1, but how about weight?
How did you come up with this?I'm going to take a big chance here, and go way out on a limb, and say it's NOT 0W-16.
One thing for sure, they make better decisions then you and I.Oh, I don't know, common sense perhaps? And the fact that for years NASCAR always qualified on the super speedways, with far thinner viscosity oil than they raced with. Why do you suppose that was?
None of them are using a 0w50. There may be a handful using 0W-30, but they aren't leading the pack. A 0w50 would be detrimental to those engines, as the ring thickness/tension and hone peaks are far too low for that much of an oil film (aka poor ring seal + high oil drag) and the amount of VII needed for that would make the oil too volatile, which paired with the high oil film thickness would mean a lot of oil transport past the rings into the chambers causing detonation galore. The bearings would likely suffer from heat fatigue from the hydrodynamic friction. They already see ~75°F oil temp rise through the bearings as it is, with a 0W-16, from hydrodynamic friction. One of the reasons they run such a light oil, aside from power, is to keep down bearing temp rise and ensure high flow through the bearings at all times. They only run ~40 psi oil pressure at full tilt, but they're send a ton of oil through the engine every minute.
The 0W-16 equivalent they use is straight base oil with no VII.
Outside of 3000+ hp Pro Mods and Top Alcohol Dragsters, not many teams in Motorsports use 50 grade oils anymore. Even WOO Sprints don't use 50 grades anymore.
I bet you $20 there is an old video somewhere of a 0W50 being blended for Tony Stewart. The video is possibly ancient but it has to exist somewhere.
Interesting I can see the 50wt but needing a winter rating is a head scratcher
20+ years ago I heard Jeff Gordon complain to his crew chief that he had less than 10psi oil pressure during caution laps. I was wearing one of those headsets you could hear them over their radio. The crew chief told him “don’t worry, you’ve got more horsepower with that thinner oil”. Guess who won the race??None of them are using a 0w50. There may be a handful using 0W-30, but they aren't leading the pack. A 0w50 would be detrimental to those engines, as the ring thickness/tension and hone peaks are far too low for that much of an oil film (aka poor ring seal + high oil drag) and the amount of VII needed for that would make the oil too volatile, which paired with the high oil film thickness would mean a lot of oil transport past the rings into the chambers causing detonation galore. The bearings would likely suffer from heat fatigue from the hydrodynamic friction. They already see ~75°F oil temp rise through the bearings as it is, with a 0W-16, from hydrodynamic friction. One of the reasons they run such a light oil, aside from power, is to keep down bearing temp rise and ensure high flow through the bearings at all times. They only run ~40 psi oil pressure at full tilt, but they're send a ton of oil through the engine every minute.
Might be 0W-8.
Funny cars use 0W-2...
Remember, NASCAR cars (driving ina circle. Ooo-wee..........) run a 36psi pressure cap on the cooling system or something crazy like that.
If they use a regular grade oil I would be surprised, because then you could make the argument that they would just use the thickest stuff they can find (40W-70?) to maintain viscosity for hours at 150-200MPH........... Which I do not think is how they do it...
Wonder if they use a Group V oil..
@High Performance Lubricants I have done nothing but speculate so far, but, do you know? About NASCAR?
I believe Pro Stock is on 0W-5 One man for sure could give us a definite answer.Pro Stock uses a 0W-2. FC/TF uses SAE 70.
NASCAR mandates a 33 psi cooling system pressure relief. At one point, they were running as high as 80 psi coolant pressure before NASCAR started regulating it.
They don't use a majority group V as that would be detrimental to anti-wear and anti-friction additive performance. I can't giveaway specifics, but the group V use is between 0-30%.
