It is a good paper. They tested:
Quote:
1 - Commercial API SJ Package A, 20W-50 Mineral Oil, Ca/Mg/Na detergent Package
2 - Commercial API SH/CD Package, 20W-50 Mineral Oil, Previous 76 Nascar Formulation
3 - Modified API SJ Package A, 20W-50 Mineral, Ca/Mg version of test oil 1
4 - European API SJ/CF Package B, 5W-50 Synthetic, High Ca/Mg Detergent Package
5 - Modified API SJ Package A 10W-30 Synthetic, Same Additives as Test Oil #3
6 - Modified API SJ Package A + Friction Modifier, 20W-50 Mineral, Top-treated with 300 ppm Mo
7 - Commercial API SJ/CF Package C, 20W-50 Synthetic, Similar additives to Test Oil #5
The candidate Oils were run in the dynamometer engine test at RCR Research. The engine components were visually rated by RCR personnel at the end of each test. Pistons, piston rings, wrist pins, lifters, and camshafts were then shipped to Lubrizol where they were photographed and rated by certified engine parts raters. Select parts were also examined using techniques of surface analysis to determine whether there was transfer of material on mating ring and wrist pin surfaces and formation of suitable antiwear films on lifters, cam lobes, piston wrist pin bores, and wrist pins.
Due to the severe temperatures and sparse lubrication, candidate oils were typically found to be either [censored] performers or cause catastrophic failure resulting in early engine shutdown.
Summary of end-of-test-parts at RCR
Oil Camshaft/Lifter Ring Weld Wrist Pin Bore
1 ... Poor ........... Poor ..... Poor
2 ... Good ........... Poor ..... Average
3 ... Good ........... Good ..... Average
4 ... Poor ........... Average .. Poor
5 ... Good ........... Good ..... Average
6 ... Worst .......... Good ..... Poor
7 ... Average ........ Good ..... Average
Conclusions:
* RCR developed a dynamometer test that correlates ring welding, wrist pin bore wear, and valve train wear with Winston Cup Racing performance.
* Low detergent packages increase the effectiveness of antiwear fil formation which minimizes microwelding. Calcium detergents performed better than magnesium detergents which performed better than sodium detergents in this study.
* The particular molybdenum compound chosen as a top treatment for friction modification did not improve valve train wear.
* Synthetic oils generally performed better than mineral oils with similar additive packages.
* A 20W50 mineral oil showed equivalent performance to a 10W30 synthetic formulated with similar additive chemistry.
