NAPA 1792XE?
Bad Axe, MI
Looking into trying this filter on some of our CAT 3406's but upon research i see it's a 5 mic filter must be a bypass filter?
seems pretty tight but NAPA's cross list it for direct replacement for this engine,anyone see a problem with this,our trucks have no bypass set ups stock filter configurations. It flows good tho 28-30 GPM
was looking at this one or the FG LF3566 StrataPore
http://www.fleetfilter.com/filter/wix-oil-filters/51792XE.html
http://www.napafilters.com/filterlookup/PartDetail.asp?Part=1792XE
According to Napa's website that's a full flow filter, so it could be a direct replacement for what you need.
What great filtration & flow spec's huh? I'd sure as [censored] want to give them a shot.
+1 i would use it... but then again stratapores are great too.
for me I would go with which one was easier to get and lower price tag.
That's what i was thinking outstanding filtration with good flow,think i'll try some.
the NAPA is cheaper vs. the FG for us.
Originally Posted By: doitmyself
How does the flow rate (28-30gpm) compare to a "regular" filter for this application.
The FG flows little more 80 gpm but filtration is not as good,28-30 gpm should be plenty.
