n00b Grease questions
CA
Can wheel bearing grease be used to lube chassis "points" such as zerk fittings, etc?
How do I "load" wheel bearing grease into a wheel bearing on a RWD car?
Thanks.
I don't see why not. Just get grease rated for both uses.
I don't believe that you do. The gear oil in the dif. does most of the lubricating.
