Well I flushed and filled two of my trucks with fords new Mercon fluid that supercedes the old mercon standard and what is now considered the correct fluid to use in place of the original mercon.
first truck was a 1993 F-450 (F-SUPERDUTY) IDI 7.3L diesel with an E4OD. the truck has a 4.88 rear end gear if that matters. Ran fine when purchased with the fluid in it (receipts that came with it said (ford mercon dated 1998 and mileage was 40K miles.)
well I went ahead and flushed with the new mercon that for swears up and down will work in these trucks. Ran it for 7,000 miles.
My observations. Horrible shuttering between gears, shift firmness inconsistency, the fluid was visibly burned and smelled burned after only 7,000 miles. It would trip the TCM into limp home mode and flash the OD off light indicating that it was going to cost me a lot of money. I would just pull the battery cables to turn the light off. 100 miles or less and the bam flashing light again.
now this truck is HEAVY and under powered, if its moving forward chances are the throttle is flat on the floor.
second truck was a 2001 excursion with the 4R100 and a 7.3L powerstroke. Also shuddered but never flashed a transmission fault light but the shuddering in that one was so horrible that I couldn't stand it and changed it in less than 2,000 miles.
Both replaced with Chevron MD-3 and honestly could not be happier. I wish I hadn't have run out of my cash of Mobil SYN atf that was mercon rated. but for the price on this MD-3 I can flush it 3 times to everyone flush of the Mobil one.
having done that test in my own vehicles theirs no [censored] way i can reccomend this "NEW generation mercon V mercon double standered sauce to anyone with a ford light truck 4spd auto.
