my steering wheel shakes -__-
Metro NY
2001 Toyota Camry 1MZ-FE approx 188,000 miles
whenever im on the freeway my steering wheel shakes when i go 65 - 75mph.
if anybody has any idea what the underlying cause of this "shaking" please let me know.
i have about 20,000 miles on the Michelin mxv4's so far
they were mounted and balanced by costco wholesale.
is it possible that the balance is off Already??
Definitely possible if your car lost a wheel weight.
did the wheel shake when the tires were new? I threw a weight within a week on my trep. on my toyota the wheel shakes with new tires - I suspect the previous owner hit something and bent the wheels - cause when I got the car at 16k it had two new tires on it and a bent hubcap.
the wheels just started to shake recently
could it be the rough road conditions with
the snow and all that cause something to loosen up?
I expect Costco will rebalance at no charge, if that balance was done when you bought tires from them.
While a balance problem is probable, you could have a bent wheel or other problem.
Yes, also check for ice or snow packed inside the wheels. The snow and ice can throw a wheel off balance.
20,000 without a balance and rotation is a long time. Just go get them balanced and they will tell you if they can't get them balanced.
First is the tire/wheel assembly.
Out of balance, out of round, internally damaged, or bent.
These are the most likely.
A bad brake rotor can also do this.
A bad ball joint or wheel bearing will make any imbalance or out of round feel much worse.
If you want to figure it out without going back to Costco, rotate the front tires to the back, and the backs to the front.
It the vibration moves from the steering wheel to the "seat of your pants", then there is something up with one of the two tires/wheels that is now on the back of the car.
Originally Posted By: Papa Bear
"Yes, also check for ice or snow packed inside the wheels. The snow and ice can throw a wheel off balance."
+1
That happens to me at least once every winter!
+1
Actually where I live we don't have this problem, but it makes sense...............
My roommate just had this happen, and it persisted after a rotate and balance...turned out he needed new tie rod ends. Took all but 10 min. per side, and all the shaking on the highway is gone now.
Or if the tires need to be road force balanced.
Strange thing is, I have the same problem as the OP, except I've rotated the tires and had the wheels rebalanced many times and I have never been able to resolve the problem. I keep getting a light vibration above 65.
