Hello Gents (and Kira),
I've been doing a little experiment with my car. It's a Chevy Volt, so it's possible to drive the car without running the engine (it's electric).
I put a Gold Plug magnetic drain plug on it, a Motion Pro Oil Filter Magnet next to the inlets of the filter, and two FilterMags around a MicroGreen oil filter, and two hard drive voice coil magnets stuck to the end of that filter.
In short, I have as many magnets as I can think of in the oil, or really near it. And, the MicroGreen has a built-in bypass filter that filters down to 2-3 microns or so.
After about 1,000 (engine running) miles on Mobil 1 Extended Performance 5w30, I switched to Pennzoil Ultra Platinum 5w30 (Yes, too soon, but I've got BITOG-itus real bad!).
I found:
On the Gold Plug, a bit of gray oil that, when wiped on to a paper towel, made that part of the towel attractable to a magnet. To the naked eye, and even using a jeweler's loop, it just looked like gray oil.
Similarly, the Motion Pro Oil Filter Magnet had what looked like gray oil that, once put onto a paper towel, made it ferromagnetic (not magnetic in itself, but attracted by a magnet).
I cut the oil filter open, and I saw the same sort of stuff (but quite a bit less of it) as shown in this picture:
http://www.rx8club.com/series-i-tech-garage-22/filtermag-alternative-45752/
(scroll down towards the bottom of the thread).
both around the sides of the filter (where the FilterMags were) and the end (where the hard drive magnets were).
My guess is that the gray oil that I see stuck to the magnets is oil with iron particles that are only a few microns in diameter (large enough to sneak through the MicroGreen bypass filter).
I'm *GUESSING* that this will help reduce wear in my engine - both the magnets and the bypass filtering in the MicroGreen filter will minimize abrasive material in the oil. I also suspect that, since I only use the engine about 10% of the time, I'll never see this engine burn a detectable amount of oil during the 2-year oil change intervals (the OLM times out after 2 years no matter how little the engine is used).
Thoughts, comments, questions, nags, harassments, etc., etc.?
I found:
