My new 2025 Subaru Forester Limited
Congrats on the new car. Beautiful color and interior. Currently own a 2021 Outback 2.5 with essentially same drivetrain. I highly recommend you stick with 5w-30 or 0w-30 in this engine. They absolutely destroy motor oil in as little as little as 2-3k miles. 5% + of fuel dilution is very common. 3% is doable in warm weather with no short tripping. Considering you’re driving 10k or less I’d stick to 6 month 4-5k mile oil changes. It’s sad Subaru has pushed for 0w-16. Meanwhile same engine FB25DI couple years older allowed for 5w-30. Mobil 1 ESP 0w-30 or a Valvoline R&P should serve you well.
Edited: changed to couple years older FB25DI.
Meanwhile same engine FB25DI couple years newer allowed for 5w-30.
uh since its a 2025 how is there an FB25DI a couple years newer?
Has the fb25-DI ever recommended thicker than 0w20?
even in 2019 the forester owners manual had this to say:
FB25DI has been around since 2019. Engines relatively the same other than the thermal cooling valve and a couple service bulletins on minor things like fuel pumps or drain plugs.
yes I'm well aware of that info.
I was trying to figure out if you had typos or what since AFAIK its never recommended anything thicker than 0w20 since 2019
Being that its never recommended 5w-30 and there is no newer engine than 2025... :unsure:
Thought maybe a phone voice typo etc.
I was referring a couple years as to the engine itself. Here is the 2019 owners manual recommendation. First year of FB25DI.
So when you said a few years newer you really meant 6 years older.. got it.
with the 1999 manual language to pick the proper thickness oil.. from back when the oil chart had multiple options.
it doesn't state or recommend 5w-30 its still the standard 0w-20 :unsure:
The other wording is also funny.. allows 5w-30 or 5w-40 CONVENTIONAL(is there one?) for replenishment
if 0w-20 isnt available.
I'd run whatever makes you happy. I did in the 4 FB25 powered subarus I owned or worked on.
Literally anything from 0w-20 to 20w-50 would work although you have to keep in mind climate and conditions.
