With this "low mileage" motor, Ive run a very short OCI of PYB because of an odd solvent smell in the bottom end.
I then ran Mobil1 0w40 for 4k miles.
My reason for changing, the oil went from like new to pitch black in the last 500 miles. Some will say that doesnt matter, Id say that 22$ doesnt matter in relation to a 1500$ motor.
Upon draining, the oil in the filter was thick, very thick compared to normal 0w40.
I drained for over an hour then dumped a new fill in with a new denso filter.
Last night I chanced upon some Mobil1 15w50 for very cheap. While well within spec for this motor in this climate (20w50) is the rec. I chose to mix it 50/50 with 0w40.
Just curious as to the additive packages of the oils, and what sort of weight Ill end up with given the sheering issues with 0w40.
Also, when I pulled the valve cover on the motor before the install, the top end was quite dirty, very dark dark brown. No sludge, but dark. Any idea of how many oil changes I should expect before I can push it out to 7500 indicated 8300 actual.
Please dont suggest solvents in the motor. Or an oil analysis. Paying people to guess based on a few numbers isnt my idea of a wise expenditure.
Not when you fine people tend to guess just as accurately...and for free lol.
