I bought one of the compression testers from Amazon ( this one).
Cyl 1: 130
Cyl 2: 130
Cyl 3: 130
Cyl 4: 135
Car was fully warmed up. Then I parked it and let it sit for 10 minutes as per the instructions. Then I took the Intercooler off, pulled all the plugs, pulled the fuse for Ign 2 in the engine bay. My wife held her foot to the floor (to open throttle plate and turn off injectors). We let it crank for about 5 to 7 seconds. It was enough that the compression wasn't going up at all anymore.
No blue smoke. The first crank yielded I think 80 maybe a bit more.
It's a 2009 Mazdaspeed 3 GT. Car has 13,700 miles on it. Don't know the elevation. Northeast Oklahoma though. All cylinders were 130 except cylinder 4 was 135. I tested 10 minutes after the car was fully warmed up and parked. The directions said to wait 10 minutes something about aluminum heads.
Also, when I added a teaspoon of oil the compression tested 150 across the board.
They are all close to each other but other people's compression for this car is 180 to 185. I think that means I'm below the 28.5% tolerance.
I have changed the oil myself. Currently has Rotella T6 in it w/ about 1k miles on it. Before that I had German Castrol in it for a run of only 1k miles and before that I had Pennzoil Platinum for a run of 2,700 miles before that was Castrol GTX for 1k miles and before that was the free oil change and it went 4k miles and before that was factory fill for just barely over 3k miles. I just bought 12 quarts of Redline 10w40 and was just about to put it in before I tested the compression, now I don't want to waste it on this engine.
The thing I worry about is since there's no CEL them saying well nothing is wrong the car is fine. But the major power loss I had led me to do this compression test as I KNEW something was wrong that I had lost lots of power. So do I just take it in and say this to them? The car wasn't stock, it had..
SRI
TIP
BPV
Racepipe
RMM
HP FP internals (worked great)
and some misc stuff like shifter bushings, new transmission oil etc.
I could probably put it back to stock in a couple of hours.
Also I've been checking and changing the plugs quite a bit. Took the stockers out for the Deno 1 step colder then I pulled them noticed a lot of oil around the edges of them. Tried NGK 1 step colder and it ran terrible so I pulled them and the same thing, oil on them. I just put in some stock NGK's. Would "blow-by" be what's causing the buildup on the outer part of the plugs?
Thanks for any help/advice.
Cyl 1: 130
Cyl 2: 130
Cyl 3: 130
Cyl 4: 135
SRI
TIP
BPV
Racepipe
RMM
