Do you burn oil? Are you a Puritan? If no to both, then keep doing what you're doing.What say you?
I rather doubt it, but go for it if you like to try new things. Unless you are burning through a bunch of oil on your current OCIs then I just don't see the point.Any point since what I've done has worked fine?
I tend to overthink.
2007 Pontiac G6 3.5 V6Year, make and model (engine size), please.
And as above, are you the OO?
It burns a little bit. Nothing crazy.Do you burn oil? Are you a Puritan? If no to both, then keep doing what you're doing.
Get the Valvoline Restore and Protect!It burns a little bit. Nothing crazy.
Agree. Why not? @jml4life said he likes to try new oils. Maybe Valvoline Restore and Protect will reduce oil burning. Worth a try...Get the Valvoline Restore and Protect!
I Agree since the Valvoline Restore and Protect could reduce his oil burning and probably clean his piston rings.Agree. Why not? @jml4life said he likes to try new oils. Maybe Valvoline Restore and Protect will reduce oil burning. Worth a try...
Valvoline HM EP 5w30After 307K, you should be telling us what to do, not asking.
What's your oil choice history with this car?
If you've used a variety of different oils, then why not try R&P?
It won't hurt and it might clear up the minor oil use.
