I have a 03 Yukon with the 4L60 transmission. It has 53K miles on it. I bought 2 bottles of AutoRx and dumped 4 quarts of transmission fluid and replaced with Valvoline Dex III and put the Auto Rx in. I ran it longer than the directions said to. I did about 2300 miles. Then I dumped the pan and replaced the filter and refilled with Supertech Dex VI. It feels much better! There is more power to the ground. There is less heat when I open the hood. Before after running all day and coming home and popping the hood would be like opening an oven door. I always thought it was the big V8. But since I did the fluid change it feels much cooler. Still hot though. Since then I have done 3 drain and fills and have enough Super Tech to do 2 more. Then I will do the same drain and fills with Castrol Dex VI. I am still debating whether or not to do the flush? Opinions? I should only have about 7% of the old fluid when I am done with all the Supertech. I also just changed the oil and put the Auto Rx in with some Supertech 10W30.
