I am with Bror Jace
Today multi-vis oils are far better and shear less. Of course companies will put more effort and reasearch into the product they sell in more volume, so single grade oils will be neglected - common sense.
Regarding startup wear, often these engines trimmers, tractors, push mowers) are started and stopped many times, so I prefer lower startup viscosity, hence multi-vis oil. Of course, if you fire up a lawn tractor and run it for 1-2 hours straight then single grade is fine as well.
Temps vary and depend on the load. I happen to have a weak engine (16HP) on my lawn tractor so it experiences higher load, hence I'll go 15W40 HDEO. If your engine is under normal/low load then you'll stick to 10W30 or straight 30. So depends not only on ambient temps but also run duration, load, etc.
You could use synthetic if you really want to take good care of it. However, if they work hard and possibly experience higher temps (air cooled), then I'd prefer dino HDEO to clean it and change oil more often to remove particles. I'd prefer 2 dino changes to a longer synthetic OCI. Also, more frequent changes will remove sheared multi-vis oil so you don't have to worry about viscosity loss as much.
Again, synthetic can also be a good choice for other circumstances, especially lighter load use, winter, etc. In fact I do use a 0W30 synthetic in my snowblower because we go to 0F and lower, so startup wear is bigger issue.
