Motorcraft specs...
USA
Haven't seen this mentioned before...Motorcraft is posting some info on their website.
FL-400S:
Part Number FL400S
Diameter in Inches 2.98
Length in Inches 4.72
Thread Size 3/4 - 16
ADB Valve Material Silicone
RVOP Setting PSI 12.5-18.5
Efficiency @ 20 Microns % 80%
Capacity gr 7
Burst Pressure PSI 200
FL-1A
Part Number FL1A
Diameter in Inches 3.78
Length in Inches 5.2
ADB Valve Material Nitrile
RVOP Setting PSI 11-14
Capacity gr 12
FL-910
Part Number FL910
Length in Inches 3.33
RVOP Setting PSI 11.6-17.4
Efficiency @ 20 Microns % 50% @ 35 microns
Capacity gr 6.5
Burst Pressure PSI 217
Similar info is available for their air and fuel filters.
Comparing to this post, the MC is below even the Premium Plus Purolators.
I always thought that the #s given by Purolator is a little high though...
