Yes, RR .Sometimes I run numbers through Purolator, Wix, Donaldson, and Baldwin..the wix site is a bit easier to navigate and gives more data (typically)
Wix
Wix doesn't differentiate between the FL300 or FL200 ..they're both 51068 to them
Baldwin doesn't differentiate them either.
Donaldson has no listing for the FL200
Hastings sees them as the same filter
Purolator has no listing for the FL200
Now a FL2005 is a 3/4-16 filter. It has a slightly higher bypass setting
Part Number: 51315
UPC Number: 765809513150
Principal Application: Ford (98-04), Mazda (01-04)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.704
Outer Diameter Top: 2.983
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 320
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.750 2.400 0.130
Part Number: 51068
UPC Number: 765809510685
Principal Application: Agco Tractors, Chrysler (70-91), Ford/Mercury (83-97), Kubota Engines, Land Rover (95-04), Toyota (68-90)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Outer Diameter Top: 3.660
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Beta Ratio: 2/20=10/26
Burst Pressure-PSI: 275
Gasket Diameters
Attached 2.834 2.462 0.200
Looks like the FL2005 is between the FL1A and the FL300 in size
Part Number: 51515
UPC Number: 765809515154
Principal Application: Chrysler Family of Cars/Trucks (57-70), Ford Family of Cars/Trucks (57-00), Mazda Trucks (94-00), Toyota Landcruiser (71-96) - (Two Quart version is 51773)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=13/23
Burst Pressure-PSI: 270
Gasket Diameters
