Motorcraft filter?
USA
I used to run the over-sized Motorcraft FL1A filter on my 1998 Jeep Grand Cherokee Laredo 6 cyl. I really like the Motorcraft filters and plan on swiching back but to the standard size. Can anyone tell me what the correct Motorcraft filter is for my Jeep in standard size? If I recall correctly, was it was the 820 or the 820S?
Thanks.
It's definately NOT the 820S, that has a metric thread. I believe the FL200 is identical to the FL1A in all specs except it's not as long. My 1996 Contour uses the FL200, though the FL1A physically fits. Though the extra length may contact the front axle in certain circumtances.
The FL300 physically looks the same as the FL200 but I'm sure there are differences, but I don't know what they are. There has to be differeneces. Otherwise why have two of the same filters
. Unfortunately the FL200 is getting more difficult to find on the "shelf". Whereas the FL300 is easily found
Whimsey
Yes, RR .Sometimes I run numbers through Purolator, Wix, Donaldson, and Baldwin..the wix site is a bit easier to navigate and gives more data (typically) Wix
Wix doesn't differentiate between the FL300 or FL200 ..they're both 51068 to them
Baldwin doesn't differentiate them either.
Donaldson has no listing for the FL200
Hastings sees them as the same filter
Purolator has no listing for the FL200
Now a FL2005 is a 3/4-16 filter. It has a slightly higher bypass setting
Part Number: 51315
UPC Number: 765809513150
Principal Application: Ford (98-04), Mazda (01-04)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.704
Outer Diameter Top: 2.983
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 320
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.750 2.400 0.130
Part Number: 51068
UPC Number: 765809510685
Principal Application: Agco Tractors, Chrysler (70-91), Ford/Mercury (83-97), Kubota Engines, Land Rover (95-04), Toyota (68-90)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Outer Diameter Top: 3.660
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Beta Ratio: 2/20=10/26
Burst Pressure-PSI: 275
Gasket Diameters
Attached 2.834 2.462 0.200
Looks like the FL2005 is between the FL1A and the FL300 in size
Part Number: 51515
UPC Number: 765809515154
Principal Application: Chrysler Family of Cars/Trucks (57-70), Ford Family of Cars/Trucks (57-00), Mazda Trucks (94-00), Toyota Landcruiser (71-96) - (Two Quart version is 51773)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=13/23
Burst Pressure-PSI: 270
Gasket Diameters
