Motor Silk (boric acid engine coat)
New Jersey
Forgive me if this has been beaten to death but my search didn't turn up anything. Has anyone had any experience with "Motor Silk"? I believe its an engine treatment that coats the cylinder walls with a boric acid treatment of some type. Supposedly lowers engine wear, less friction, better gas mileage and used more by the trucking industry. I'm curious if it works.
Thanks for the response but when I followed your advice all that appeared was my request and your response. Can you tell me what I'm doing wrong?
+boric and +boron (separate searches) will grab you a few things too in Fuels/Fuel & Oil Additives. This is still the only used oil analysis I could find where someone documented use of it.
