Motor oil for hot summer (evolution 9)
Thats help me alot now!
Originally Posted By: JRed
No reason to go above a 40-weight oil unless you're tracking it enough and reaching oil temps high enough to justify a 50-weight oil.
Running around with 20w-50 in the pan @ 220F oil temps isn't necessarily a good thing from an oil flow standpoint.
Rotella T6 should be fine. Rotella T5 would probably be fine. Redline is probably about as good as it gets for your needs.
You could run Delvac 15w40 if you felt the need. It's good stuff, but I wouldn't run a track day with it.
