Motomaster Supreme 10W30
OTTAWA, ON, CA
Canadian Tire Corporation Motomaster Supreme 10W30 SM GF-3/4. I have to disagree with the "Odor Normal" as this oil smells bad.
code:
Oil Brand: Motomaster
Oil Series: Supreme
Oil SAE J300: 10W40
API SX: SM GF-3/4
Antimony Sb NR
Cadmium Cd NR
Vanadium V 0.1
Aluminum Al 0.9
Chromium Cr 0.2
Iron Fe 0.6
Copper Cu 0.2
Lead Pb 0.6
Tin Sn 0.0
Molybdenum Mo 27
Nickel 0.0
Manganese Mn 0.1
Silver Ag 0.3
Titanium Ti 0.1
Potassium K 2.6
Boron B 172
Silicon Si 4.4
Sodium Na 0.0
Calcium Ca 1552
Magnesium Mg 5.7
Phosporus P 446
Zinc Zn 566
Sulfur 2296
Barium Ba 0.1
cST @ 100 C 66.3
cST @ 100 C 10.6
Viscosity Index 148
Water Negative
Appearance Normal
Odor Normal
TAN 1.94
Wear Check comments: The iron level is marginal. There is a moderate concentration of dirt present in the oil. The oil viscosity is lower than typical, possibly indicating the addition of lighter grade oil.
Is this a used oil analysis or a VOA?
Why would there be dirt in virgin oil?
Oh, and where did you get the analysis done?
And how much did it cost?
This is a VOA of 10W30, not 10W40; I've got to start triple-checking what I do for the data entry.
I'm not sure why there is dirt in the sample, I opened the bottle of oil, opened the sample bottle, and poured the oil into it, then capped the sample bottle. It seems like the dirt is there from the bottling process???
The analysis was done by Wear Check in Mississauga, ON; sorry I forgot to add that in the original post. I've no idea how much it cost as I bought the kits last year. I also sent a VOA to Toromont-CAT in Orillia, ON, so I'll post those results when I receive them.
The levels of additive in this VOA look nothing like those in my used oil analysis...
Yea, the additives are nothing like what you saw in your UOA which is strange.
Still not a bad oil for the price though when it is on sale.
VOA by CAT Toromont
code:
Oil Series: Supreme
Oil SAE J300: 10W30
API SX: SM GF-3/4
Antimony Sb NR
Cadmium Cd NR
Vanadium V NR
Aluminum Al 3
Chromium Cr 0
Iron Fe 13
Copper Cu 4
Lead Pb 0
Tin Sn 0
Molybdenum Mo 40
Nickel 0
Manganese Mn NR
Silver Ag 0
Titanium Ti NR
Potassium K 2
Boron B NR
Silicon Si 12
Sodium Na 3
Calcium Ca NR
Magnesium Mg NR
Phosporus P NR
Zinc Zn 862
Barium Ba NR
cSt @ 100 C 10.5
TBN 8.0
AntiFreeze Negative
Fuel Dilution Negative
Water Negative
This VOA was taken from the same bottle at the same time as the WearCheck one. For some reason it took a little longer to get to my mailbox.
Please note that the 1st cSt on the WearCheck VOA above should be listed as cSt @ 40 C 66.3.
The sulfur levels on two Mobil 1 used oil analysis on my ZZR250 were quite high, 2590 and 2405, and the used oil didn't stink like this new oil. Could it be a synthetic compared to conventional issue?
If I recall, sulfur level is tied to the Group level of the oil. Group I has the highest allowable sulfur level, which might say something about this oil.
Someone please correct me if I'm wrong on this.
Guys, thanks for the comments on sources of sulfur.
dave1251 : It is 10W30; I corrected myself in my 2nd post of this thread. This is a VOA of 10W30, not 10W40; I attempted to correct my typo but was unable to
Both of the VOA's are 10W30, they are from the same bottle and were poured into their respective sample bottles at the same time.
BlazerLT : CAT-Toromont does not test for calcium. As stated before here on BITOG, their tests do seem lacking in the elemental results of their spectroscopy tests
I'll be using WearCheck after I use up my CAT-Toromont kits.
I guess these analyses can outline the variances in results from different labs?
