Changed alot of oil and filters in my time, one is rather interesting. My friend had bought a 2009 Subaru Forester to use with his line of work, not a high paying job but enough! He uses his Subaru to deliver newspapers on a rural route. Length is about 30 miles but all stop and go in all weather 362 days a year. He insists on using Motocraft semi-synthetic 5W-20 or 10W-30 every 3000 miles, with filter change. OEM filter is used and I do the work. I can attest that the little Subaru is rather subject to heavy duty driving much like a taxi cab!
Drained oil is always jet black but the filler cap is clean and the egine runs like a clock with a bit of noise when started below 10 degrees F. So I think it is a good oil for these conditions and protects the engine.
He goes through a new car every three to five years and follows the same oil change interval. On a Dodge Stratus he had a oil pan gasket leak at 50k miles and the engine was looking like new with zero sludge and a small amount of debris in the bottom of the pan.
poikaa
poikaa
