I've spent most of my morning reading old BTOG posts about PEA, Techron, Royal Purple, Techron, and others. (How sad!) The reason being is my recently purchased 2007 Lincoln MKZ with 125,000 miles gets horrible gas mileage. Especially when I compare it to my recently departed (sniff) 2000 Buick GS. Larger, heavier, almost double the mileage, same displacement, same HP. Real world, about 18-19 around town, 23 on the highway. The Lincoln is EPA rated at 19 and 27. That's running Mobil 1 0W-20, the Buick ran Mobil 1 20W-40. Using the built in computer, I get 13mpg on, yes, very short in town jaunts, gets up to about 16+ combined with a short freeway hop. This is SO far below what the Buick did and the EPA claim that it really urinates me off. This isn't some margin of error, climate, or mechanical issues. In fact, I'm driving the Lincoln more conservatively that the Buick!
I've been turning wrenches for over sixty years, I've gone through the obvious and accessible. As an example, pull a spark plug. Perfect in gap and condition.
I've no complaints about power or drivability.
So, I'm getting desperate and thought I'd look into a PEA fuel additive. Other than a few dollars, what's to lose? (The only other thing I can think of is that the internal water pump was replaced maybe 5K miles ago by a previous owner, and maybe the mechanic didn't get the cams aligned right, off a tooth? I don't want to even think about that fix.
Back to the topic, PEA additives. In hours of reading, so much opinion, so much subjectivity, so much bad science with a smattering of objective experiences. I figured I might as well get the most PEA bang for my buck. (I know that all PEA's are not created equal, but I need to keep this simple.) I looked up the SDS's for Royal Purple Max Clean, Redline Si-1, and two Techrons, High Mileage and Complete. Since SDS's give a range of ingredient percentages, I went with the average of low and high. Those results are:
Royal Purple, 10%
Techron Complete, 15%
Techron High Mileage, 22.5%
Redline, 31%
Since the bottle sizes and prices vary for each product, using a local national chain prices, I came up with the following cost per ounce of PEA:
Royal Purple, $10
Techron Complete in 32oz, $4.69
Techron High Mileage, $4.81
Redline Si-1, $3.44
It's obvious which one I'm going to try. Now, should I go for the total dump, or divide it by two or even three tank fulls? The latter would be the equivalent of three Royal Purple treatments. Man, a guy can go nuts trying to figure this all out.
