Moog Lower Ball Joints, Lower Control Arm Bushings, Outer Tie Rods.
UMI Sway Bars with Poly end links & mounts, 35mm front, 22mm rear.
AC-Delco reman Rack & pinion.
Royal Purple Max E-Z PS fluid.
Hotchkis Super Grease (Silicone) on all the Poly bushings.
Valvoline #2 for the ball joints & tie rods.
A buddy at a local Firstone let me use their alignment rack.....
.02 degrees total toe.
-.01 degrees Camber (Both)
3.0 degrees Caster (Both)
Drives great & the bigger sways didn't alter the ride quality all that much....Not that it rode like a Cadillac in the first place. Noticeably better cornering!!
