I posted before about using a shop vac to instantly unclog drains. Here is another trick. I had to change the wax ring under a toilet and had very little time. I drained the tank and bowl trap with a powerful wet/dry shop vac. 20 seconds and the toilet was dry and could be lifted off the mounting and set aside without the usual water spill.
Now if only I could fix the lower back pain from lifting the toilet
