More Saab brake hose difficulty
MD
I posted a few days ago about the front hose on my Saab 9-3. Today I changed the rears.
I had some difficulty on one side. I think it's okay now, but I was wondering whether I need to worry about further issues.
This car uses a banjo bolt to attach the hose to the calipers. The left side went on reasonably well, but leaked a bit after I had it together. I tightened the banjo bolt a little more, but it still leaked. Upon taking it apart, I noticed some corrosion and debris built up on the caliper near the fitting, so I took a fine file and dressed the area, followed by 600 grit and 1000 sandpaper. I also flat sanded the copper washers to make sure that they were flat. I put it all back together, and it all seemed to fit better. I appears not to leak.
I assume all is well now, but I don't have a lot of experience with these banjo bolt fittings. Do I need to keep an eye on this fitting now, or worry about a leak in the future?
I did reuse the washers that I first installed, but I sanded them to remove some of the ridges from the first install.
Removing any corrosion is a must for a leak free seal, you have done that and it is not leaking so forget it. Any further issues use aluminum washers, they are softer and provide a better seal.
Thanks Trav. The original washes were aluminum. I suppose I could try to recondition them.
I tried to get some washers the other day at NAPA, and it was hopeless. Advance was a little better with a Dorman kit, but their selection was also poor.
I rechecked this morning. The fitting is seeping a little. I'll change the washers to see if that helps.
That's two Washers per Banjo Bolt .... correct ?
---- Bolt Head (top)
---- Washer
---- Block with Brake Hose
---- Washer
---- Caliper (bottom)
Yes.
I took it all apart again. I sanded flat the original washers and reused them. It's still leaking.
I am trying to find new washers, but it's proving difficult. They seem to be 17mm O.D., 12mm I.D., 1.5mm thick.
Yes.
Go to a NAPA Store and see if they can help you.
Don’t sand copper washers, ever, you’re introducing tiny, oil-leaking, flaws in the surface.
You can re-use them (if they haven’t been ruined by sanding) by annealing - heating them cherry red, and letting them cool. It softens them and they can be reused.
Go get new washers. Remember the anneal trick for next time.
It costs less than $20 for a big assortment of copper washers on Amazon, so I keep an assortment on hand.
