I would use an after market filter or the Nipon Denso or whatever alternative. Both seem better filters than the PH 3950 that was the last Fram I ever will buy. It does seem to have a silicone ADBV and much more filter area than the 3 3/4'' x 3'' PH 3950.
Some good data, but I fault some of the conclusions.
Orange doesn't guaranty silicone rubber. When I worked for a wire manufacturer, they make all sorts of orange rubber.
10 little holes may not flow more than 8 bigger ones. Got to look up flow through holes. In pipes, it is not the square of the radius, but the 4'th or 5'th power. A 5 mm pipe will flow less than half a 6 mm one at the same pressure and viscosity.
I doubt a ''perfect'' hard plastic to metal bypass seal: I like metal to rubber better.
''The can is smaller, 80% of the old one, so would take slightly less time for the engine to build pressure on a cold start, when the center pipe would be dry. '' Not unless the orange ADBV failed.
I am glad the ST 3950 still has a metal to rubber bypass at the thread end and metal end caps.
