- Joined
- Dec 20, 2024
- Messages
- 1,715
I managed to stupidly break the lip of my AC compressor's housing (where the compressor pulley sits) while trying to change a bad pulley (Denso 7seu17c). Serves me right. Here's the current situation::
Thanks
- I have a used compressor. Supposedly works. Still packed.
- The original compressor is still mounted on the engine. The whole AC system is still pressurized. The compressor otherwise works, so there's no debris in the system or anything catastrophic. It's just that my plans of replacing just the pulley are - well - no more.
- The car is on jacks, can't start the engine in an easy way (oil cooler and oil lines are out to access the compressor's pulley). So I can't easily start the engine to drive to a shop.
- I know very little about AC systems. I know that this thing should not be vented, and the nice polite me wouldn't do it. I live in a wooded area though, so I wouldn't rule out someone more nefarious walking to the car in the middle of the night and venting the system out, or in a vessel full of some liquid such as pure water. Or something. Or a used propane tank or anything.
- Bite the bullet and reassemble everything with a shorter accessory belt (which I have), bypassing the AC compressor > Drive to my local Valvoline > Have them empty the system > Drive home > Disassemble again > Replace the compressor with the "new" one > Add the maximum amount of PAG oil (because the system is empty right) > bolt everything > Drive back to have the system refilled or...
- Vent the system > Replace compressor > Measure how much oil I got out of the one I removed (original one) > add that amount to the "new" one + 1oz for the dessicant which I'll probably also replace if I open the system > button everything up > go to Valvoline for refill ?
Thanks
