95 Corolla with MacPherson strut type suspension. Used to have some camber problem because my dad always park too close to the curb and probably have bent something. Had camber kit installed and new struts about 45k miles ago. The tire shop said they couldn't get the alignment perfect (already maxed out) and it is still off by a little out of spec.
The outside of the tire on the front always wear out faster than the inside by a little, and it wasn't too bad until this week. My mom started driving (pass the exam at the age of 60) and accidentally hit the curb when getting into the gas station. The hub cab is about 1/6 destroyed along the cir, and the tire is a little piece of the tire sidewall scratched away.
I tested the car out and the steering seems off. Took a look at the ball joints, the tie rod end links, wiggle and tested the wheel for play, and everything seems fine.
I've heard that strut mount bracket can bent when you hit a curb, is that true? If this is what happen, how can I fix it? New struts? camber kit? shim? This car has no front sway bar and the bushings are integrated with the lower control arms, and you have to replace the control arm to replace the bushing.
