There are a lot of modern engine oils that do not use 'soluable moly' in their formula. Some people don't like to see that, but the answer from others is often "Don't worry about it, an oil does just fine without it".
Fair enough - there are a lot of UOA's from oils that don't use oil that are just as good as those with.
BUT, if this is the case, and moly really isn't that important of an additive in engine oil, why does it have a long, very detailed article on the mechanics of it, and only it, on the front page of this site? It must be pretty important - you don't see long articles on 'Boron basics' or 'Calcium basics'.
