I have two Pratt and Whitney aircraft engines, one a 985 cu. in. Wasp, Jr. and the other a 1340 cu. in. Wasp, on planes that are not being operated for a long period of time (years, in the case of the 1340) because of restoration and maintenance. These are both large bore, 9 cylinder radial (round) engines mounted on the planes and are hangared in a dry, inland San Diego climate.
My normal preservation method has been to periodically (semi-annually) spray the inside of each cylinder, using an engine cleaning gun, with Marvel Mystery oil through one of the spark plug holes with the piston at BDC on both intake and exhaust strokes (to also coat each valve in the open position). Every few weeks I then pull the prop through about 15 or 20 blades (8-10 revolutions) to keep the oil distributed on all surfaces and also pump oil through the lubrication system.
I am now thinking of spraying the cylinders with Lube Control, after the MolaSoak method to clean any carbon and/or lead (yes, I have to use leaded fuel in these engines) out of the cylinders and ring packs. My question is this: considering both the desire to clean, and the need for long term lubrication, would LC or AutoRX be the best product to use in this application?
I have always wondered why MolaKule used LC in the MolaSoak instead of AutoRX, or even MM, because I understand LC to be primarily an anti-oxidant as opposed to ARX and MM, which I believe are primarily cleaners. (You reading this Mola?)
Has anybody ever made good side by side comparisons of these three different products as long term carbon/combustion deposit cleaners?
