Mola's brew
wasn't it the opposite way around???
Time to do a search... let us know what you find. Be sure to put the time to 5 years from the default 1 week for best results...
JMH
That, and some octane additive.
MolaSoak is LUBE CONTROL LC-20 (engine oil additive) and SCHAEFFER'S Neutra .
The original posting is back in late '02 or early '03. I have posted on MolaSoak several times (used it successfully).
A few questions regarding the Mola-Brews:
1) For the oil brew, any idea what ratio to use with FP3000? Would it be 50/50?
2) For the oil brew, is the "nuetra" the same as used in the fuel brew (#131), or is it the #132 with MicroMoly?
I like the products I purchased from Specialty Formulations. I hope that he resumes business soon.
I would try Mola Brew and Mola Soak....if only I could get Shaeffer Neutra #131.
I have a fresh gallon of FP-3000 and LC-20.
I have not found an easy way to buy Neutra #131.
I have one employee with a Saturn that has the all too common Saturn oil consumption problem. He has tried the Sea Foam soak, with Sea Foam in the gas tank and crankcase.
I wonder if Mola Soak and Mola Brew might free up the piston rings and help reduce the oil consumption?
