Moen Push / Pull / Twist Faucet Cartridges
Lake Havasu City, Arizona
I have been dealing with these things for over 25 years in both bathrooms in the last 2 homes I've owned. The biggest problem is the rubber O-Rings and seals inside dry out and get stiff and hard over time. The faucet then slowly becomes more difficult to operate.
If you keep fighting it, the rubber will start to crack or tear, and the faucet will start to leak. This is especially true with the most common model, the Moen 1225. Over the years I have tried most every type of grease and lube on these faucet cartridges, and I finally found one that really works.... And above all, lasts.
I don't know why, but this Danco Waterproof Silicone Grease does. Far better than any other I tried. Stay away from some of these so called, "plumbers greases". Many are very thick and stiff like wheel bearing grease, and are much too thick. They also seem to cause the rubber to swell, which only exacerbates the problem.
https://www.amazon.com/dp/B000DZFUPC/ref=pe_386300_440135490_TE_simp_item_image
When I replace a cartridge I get a bottle brush that fits the hole for the cartridge nice and tight, and brush it out as good as I can. I generally spray WD-40, or some kind of solvent inside while I'm brushing.
I then use a wooden dowel with a rag on the end to clean it out as good as I can. Then I liberally coat the inside with the Silicone grease, and the entire outside of the cartridge itself. You can't possibly overdo this.
I then install the cartridge. Using this process I've found the faucet will not tighten up over time. At least nowhere near as fast as before with other types of lube. And don't overpay for the cartridges.
I bought this 4 pack from Amazon for just $30.00. They work and last just as long as the Moen models do at 1/4th the price. And they come with 2 types of retainer clips each. I always keep several in stock. I've gotten to the point now when they start getting tight, I'll just swap them out.
https://www.amazon.com/dp/B0BXXJCS6X/ref=pe_386300_440135490_TE_simp_item_image
I've found that the free* cartridges from Moen come pre-greased. Are you saying that the amount is not enough? IF so, good to know.
*Conditions apply
Is it like this? I was going through them annually. This last one has lasted three years. I can't remember if I used Super Lube O-Ring or Sil-Glyde. Either way, this one has been lasting.
Yes, most all of them come "pre greased". But I've found in dealing with these things for so long, that if there ever was a case where, "more is better", this is it.
I have found on the 1225 Moen, what really helps is to cover the entire cartridge liberally. Especially the smaller recessed areas of the cartridge. It acts like a type of "reservoir" where grease can remain after it's installed, that helps keep the O-Rings and rubber seals well coated.
The first time I had these replaced in my other house I hired it out to a local plumber in the area. He just took them out of the box, and right into the faucet. It worked like new after he left. But after a couple of months it began to tighten, and continued to do so.
When I started doing it myself I found more silicone lube was better, and helped the cartridge stay free moving longer. This may vary depending on the condition of your water. But I really believe you can't get too much lube on them.
Any excess will get rinsed out in short order.
Yes, that looks like the Moen 1225 that I use, and linked to. There isn't anything to really "break" with these things. It all boils down to keeping the rubber O-Rings and seals lubricated. I get about 2 to 3 years out of them in both my showers.
What's funny is the house we had before this one we purchased new. Both baths took the same Moen 1225 faucet cartridges, and both worked beautifully.
We only used the shower in our master bath. The other just sat with little to no use, except when my wife cleaned it. When we sold to move here I noticed our master bath shower valve was getting really tight. So I was going to replace it, because I figured the house inspector would flag it if I didn't. (They tend to nitpick everything).
Just for the heck of it I checked the guest bath which we never use, and it was even tighter and more difficult. So I ended up replacing both. Even from little to no use the thing got dry, swollen, and tight.
And for what it's worth, if you're dealing with these things, be sure to buy the tool to remove them. It's way better than fighting with pliers or Vise Grips.
https://www.walmart.com/ip/Faucet-C...7ikFZH12knuithGGFW2c83y4I1bdyIKQaAnLUEALw_wcB
Proper tool helps. I removed mine by wrapping an old hand towel around the outer cover and a pipe wrench. Lol.
Dow corning 111 silicone valve lubricant is what we used at the hospital in faucets valves etc. when i was in maintenance.
