Has the indicators of significant fuel dilution, which could be causing the high wear numbers. E.g., low viscosity and low flash. And, no, BS doesn't measure fuel dilutuon so you should always ignore BS fuel values. Not sure if your engine is known to have fuel dilution issues . . . sure others will comment along these lines. As PPWarrior said, a way to address this is to try an xw40.
