Just got my Mobil1 5w-30 results after 5500 kms, which is just over 3000 miles or so. Overall numbers are decent, wear numbers were a bit lower with the German Castrol 0w-30 though. But I'm still happy with the Mobil1 performance. And for some reason I find that the car runs smoother with Mobil1, so I was hoping for a good result.
Mobil1 5w-30, run on a 2002 Honda Civic SiR, 2.0L engine, 5500 kms. Mixed city and highway driving. Oiled foam Comptech/Uni air filter which hasnt been cleaned since installation in June - still looks good, similar numbers to stock air filter element.
Iron - 6
Chrome - 0
Moly - 73
Aluminum - 3
Copper - 3
Lead - 2
Tin - 0
Silicon - 9 (Mobil1 starts with 4)
Sodium - 12
Zinc - 873
Potasium - 2
Nickel - 0
Silver - 0
TBN - 9.5
Viscosity - 9.2 cst.
no oxid. , nitr. or soot data numbers this time for some reason. no biggie though.
One note on viscosity, I find this lab's numbers are off by approximately 1.0 full point at least. My last few samples have all read low viscosity on some pretty tough oils. For example German Castrol 0w-30 was 9.6 cst, Redline 10w-30 was 9.1, and Redline 5w-20 was only 7.6 !. Gotta be a problem with the lab or my little engine is really hard on motor oil (which I doubt).
Overall in comparison to the German Castrol , Mobil1 had more iron wear and a tiny bit more aluminum wear. My iron numbers with GC were 9 ppms, but the virgin sample I provided at the same time was also 9ppm, so I assumed the Iron wear for GC was zero if you subtract the virgin amount from the used amount, dunno how reliable that is though. Hard to believe that there could be zero iron wear but I dont know how else to interpret the GC results. I hope to find out with further GC analyses.
In comparison to Redline 10w-30 and 5w-20, the Redline samples were almost identical in wear for most metals, but with a good bit more lead wear numbers at 8-9 ppms of lead. Thats at least 4 times the amount of lead wear of Mobil1 or German Castrol for that matter.
any questions feel free to ask.
Joey
[ October 01, 2003, 06:51 PM: Message edited by: Idrinkmotoroil ]
Iron - 6
Chrome - 0
Moly - 73
Aluminum - 3
Copper - 3
Lead - 2
Tin - 0
Sodium - 12
Zinc - 873
Potasium - 2
Nickel - 0
Silver - 0
TBN - 9.5
Joey
