The latest from my Concours -
Earlier UOA is here -
http://www.jimsharpphotography.com/oa/Concours_oil_anaylsis_1.jpg
And thread here - http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1590619
This is certainly underwhelming. Wear metals are better than the previous report but still not very good. The fuel dilution is a worry. It makes me wonder if I don't have a float needle leaking. I should probably check that this winter.
To make matters worse, with the factory oil cooler with no thermostat the oil temp on these bikes never really gets high enough in cooler weather. I've checked with my IR gun and after a 45 minute ride in 70+ degree ambient the cooler is about 155 degrees. Others with oil temp gauges have confirmed similar oil temps in similar conditions.
I think I'm going to start blocking airflow to the oil cooler when the temps are below 70 degrees.
I changed the oil and filter. The bike now has Amsoil MCF and a K&N oil filter as used on this interval. I'll run it 4000+- miles and check things again.
Comments welcome!
Comments welcome!
