Originally Posted By: mva
Originally Posted By: JOD
You should probably give
this long, painful thread a read.
I came across this when helping a buddy of mine do the transmission fluid on his 1000HP Supra... It has a similar, though not identical transmission. Evidently, there were a number of reported failures with Redline MTL, and after reading though this thread, I actually believe it.
XOM does not make a suitable lubricant for this application. The general consensus from that thread seems to be OEM or RP. FWIW, the Supra guy ended up using Motorcraft XT-M5-QS:
PDS Link.
problem is, it's probably made by Castrol. I'm not actually sure what went into his decision to use the Motorcraft stuff, but knowing him he researched it to death before using. So, you may want to check that out.
Very interesting VOA of the BMW fluid in that old thread:
BMW MTF-LT-1
cSt@40 c 37.5
cSt@100 c 7.5
Viscosity index 172
SUS @ 100F 190.1
SUS @ 210 F 51.3
silver Boron 205
Aluminum 1
Calcium Cadmium Chromium Copper Iron Magnesium 2
Manganese Molbdenum Sodium 2
Nickel Phosphorus 484
Lead Antimony Silicon Tin Vanadium Zinc 7
Total Acid Number 0.63 mgKOH/g
viscosity -cP @ -10 c 2116
viscosity - cP @ -20 c H 4757
viscosity - cP @ -30 c H 12347
viscosity - cP @ - 40 c H 38246
Synthetic oil with boron-phosphorus ep package. Viscosity does not meet Dexron and mercon low temperature requirements.
Other fluids I have run in my BMW for comparison; note that RP has significantly better low temperature properties than the stock fluid:
RP Synchromax
Vicosity at 40C = 38 cSt
Viscosity at 100C = 7.7 cSt
viscosity - cP @ -20 c 1050
viscosity - cP @ -30 c 2730
viscosity - cP @ - 40 c 8430
Pour point = -54C
Mobil 1 ATF Dex III
Vicosity at 40C = 36.3 cSt
Viscosity at 100C = 7.4 cSt
viscosity - cP @ - 40 c 10040
Pour point = -51C
Castrol Dex VI
Vicosity at 40C = 29.8 cSt
Viscosity at 100C = 6.0 cS
Pour point = -40C
Amsoil MTF
Vicosity at 40C = 47.1 cSt
Viscosity at 100C = 9.6 cSt
viscosity - cP @ - 40 c 38273
Pour point = -45C
IIRC, there were grumblings in that thread that the fluid that came OUT of the transmission was note the same as what you were putting back in. That what came out was heavier. Too bad we don't have a used oil analysis of it.
