- Joined
- Oct 13, 2022
- Messages
- 64
Fram Force. I have an ultra, couple of XPs, an AC Delco and a Titanium in my little horde. I also have another 212A in the box as well but it’s going in the trash.interesting that we’re seeing so many failed 212a sized filters. i have posted a torn 212a and have had end caps pop off like that. what filter did you spin back on it?
Cut it open and post it before tossing it.Fram Force. I have an ultra, couple of XPs, an AC Delco and a Titanium in my little horde. I also have another 212A in the box as well but it’s going in the trash.
fram force is the AC Delco in a fram can, champs built. IMO, i would look at the carquest premium 84502 (premium guard with a silicone gasket) or roll on with the Endurance FE-10575Fram Force. I have an ultra, couple of XPs, an AC Delco and a Titanium in my little horde. I also have another 212A in the box as well but it’s going in the trash.
i take it back, the fram Drive is the champs built version. the force is a extra guard with a grippy finish. i wouldn’t run it but many here would. i’m a solid no on anything with “soft” end capsI’ll cut the Force once it’s done a few thousand miles and post.
Purolator has been popping caps for a while, it’s hard to get potting glue to stick to a metal end cap, apparently. The spring does keep it together, but the excess glue & torn media are no bueno!How many miles did you run it? Still shouldn't have loosened its end cap. They should be using a better potting glue.
Miles ran on filter 3756 miles.![]()
